• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Product Support
    Re: Catalog error since SP1
    11-09-2012 02:40 PM in reply to: jbunch55
    When you go to place the wire, use Shift + Right-click to bring up the Osnap menu.  Choose 'None' and then you should be able to place the wire with no snap marker involvement.
    Zac Travis
    GCSO - Frontline Technical Support
    Please use plain text.
    11-12-2012 05:33 AM in reply to: ztravis
    That’s just for ACAD Osnaps, right. Does that disable terminal snaps?
    I tried setting it to "None" but that didn't seem to help.
    My block has the attribute “TERM04” and sometimes I don’t want to snap to it...
    James Bunch
    Active Member
    11-13-2012 12:14 PM in reply to: jbunch55
    James,
    No I was not using a secondary catalog, but on 3 of the occasions I did modify the table headings (changed names of the USER1-USER5 columns) shortly before the freeze. This last freeze occured with a virgin database. I opened up a drawing with components in place already and then tried to do a lookup. The components at the time were not in the catalog so I was doing a lookup so I could be able to add them. It has happened 5 times now on two seperate machines. Has to be some kind of user error but we aren't sure what.
    11-13-2012 02:12 PM in reply to: jdenny
    Jeff,
    That's sounds pretty much like what I did.
    I incorrectly  modified the catalog and when I went to use the "Look Up" function it gave me an error saying my catalog didn't have the appropriate categories filled out. Which was true, I had blank information in some of the columns that require something and I also modified the headings.
    So then I reverted back to an unmodified catalog and then it started freezing on me.
    James Bunch
