• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    Catalog Number automatically resets
    71 Views, 3 Replies
    08-28-2012 09:41 AM
    When I go to change a catalog number of a relay coil for example I can go into the database, navigate to my desired part number, select it.  When I click on OK it resets it to what was there before.  In this case nothing becuase I inserted a saved circuit.  We just had a new catalog database made and changed our drawing templates and I am wondering if anythign in the setup may have cause this.
    Please use plain text.
    Active Contributor
    Re: Catalog Number automatically resets
    08-28-2012 09:52 AM in reply to: priva2
    I am playing around with it some more and it appears our new CAD setup does not like copying and pasting circuits with the copy command.  Either we need to use the copy circuit function or we have do a drawing retag/update.  Our new CAD setup must have some issues with how we used to do designs.
    Is there anyway around this as copying circuits is much faster for us rather than retaggin or copying circuits?
    08-28-2012 10:39 AM in reply to: priva2
    Just using ACAD's Copy function is not enough because of everything going on in the background of ACE. You can copy a circuit using "Copy" but you will need to retag everything. Using the "Copy Circuit" gets around this.
    Sorry if this is not the answer you are looking for...
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    08-28-2012 10:45 AM in reply to: testsubject
    I see now that is an option for us, either that or use the copy circuit command.  I guess the way we had CAD Electrical setup before this did not matter.  Hopefully the time saving elements built into aour new CAD setup will outweigh this and some of the other slow downs we have encountered.
