• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Active Contributor
    Accepted Solution
    Catalog Database
    234 Views, 3 Replies
    12-03-2012 09:21 AM
    i am wondering if there is a way to edit the way the default cat database shows items in the parts catalog. i want to be ablle to go to my panel layout, icon menu, insert footprint, red light, catalog lookup, and be able to only show the items that i want. My default is set to show AB 30.5mm lights. Is there a way to change this default?
    Autocad Electrical 2013
    Please use plain text.
    *Expert Elite*
    Re: Catalog Database
    12-03-2012 10:59 AM in reply to: Vulcan1970
    In the catalog database, there is a table called _LISTBOX_DEF.
    Edit this table to select the default items that appear when each different family table is opened.
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    12-03-2012 11:28 AM in reply to: testsubject
    Thank you for the quick response. I found the table and made the change.
    However, It is not showing up. I tried shutting down AE and also tried AEREBUILDDB. I checked the file path and i believe i changed the correct file. Is there a command that is suppose to update this change?
    Active Contributor
    12-03-2012 11:50 AM in reply to: Vulcan1970
    I spoke to soon
    I typed in the new change in the parts catalog pop up and then the next time i opend it, it was corrected
    thank you
