AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Cable from-to for mounting
34 REPLIES 34
Message 1 of 35
galashkina
5872 Views, 34 Replies
On my circuit has a few cables. The report includes connection cable wires:
W1 - From U1: 1 to FW1: A
W1 - From U1: 2 to FW1: B
W1 - From U1: 3 to FW1: C
W2 - From U2: 1 to FW2: A
W2 - From U2: 2 to FW2: B
W2 - From U2: 3 to FW2: C
When assembling the product is not used individual wires, and the cable is laid entirely, therefore need a report as follows:
W1 - From U1 to FW1
W2 - From U2 to FW2
That is, should be reflected in the report, which components are connected to cable.
Can I get in AutoCAD Electrical such a report?
Maybe help User Post?
Thanks in advance!
34 REPLIES 34
Message 2 of 35
galashkina
in reply to: galashkina
This question is very important for me.
Please someone answer it.Smiley Sad
Message 3 of 35
rhesusminus
This can be done via manual editing of the report, or by programmring an user post that removes all but one copy of all the cable tags.
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 4 of 35
rhesusminus
Well, I hate AutoLISP, but sometimes you just have to bite it and get going.
So, here it is, my first User Post. This User Post will, in a Cable From/To report, remove all child symbols, leaving only the parent symbols and then, in theory, what you're after.
This was made with AutoCAD Electrical 2014, but SHOULD work with earlier versions.
Do as follows.
  1. You should find the folder C:\Users\Public\Documents\Autodesk\Acade 2014\en-US\Support
  2. In this folder you'll find many files, but take a backup of cablecon.dcl and cablecon.lsp
  3. Unpack the contents of the attached Cablecon.zip into this folder, overwriting the original files.
Now, as you run the report generator (Use the Cable From/To report), you should be able to press the User Post button and select the fourth option.
Here it is, running on a project I had lying around, with about 100 cables in it:
Oh... Did I mention that I hate AutoLISP :D?
Trond Hasse Lie
Ctrl Alt El
Message 5 of 35
drathak
in reply to: rhesusminus
Sweet!  I need something like this as well.  And it gives me a jumping off point for doing some other user post work myself.
Thanks!
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
Message 6 of 35
galashkina
 rhesusminus, thank you so much!
Grateful mankind will not forget you!
Message 7 of 35
jmterlap
Where do you add the VIA information for Cable From/To reports?  For example, if you want one cable VIA the AC tray and one VIA the DC tray between two of your panels?
Thanks.
Message 8 of 35
testsubject
in reply to: jmterlap
I cheat with the cables and use a location code for the conduit for each cable I use:
+CON1
+CON2
Then when I run the report for +CON1 I only get the cables running in it.
For the End to End wiring I run a different report but select it for each panel end: i.e. +PEN1 to +PEN2. This will include wires and cables that connect the two panels.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Message 9 of 35
rhesusminus
There have been som major changes the lsp-files for user posts, so I had to do some changes to make my user post work in AcadE 2015.
Attached is an updates version.
Installation instructions as in this post: http://forums.autodesk.com/t5/autocad-electrical-general/cable-from-to-for-mounting/m-p/4797875#M340...
Just replace "2014" with "2015" Smiley Tongue
Trond Hasse Lie
Ctrl Alt El
Message 10 of 35
galashkina
Thank you very much!
I checked, it works!
I'm happy!
You are indispensable assistant!
Message 11 of 35
galashkina
AutoCAD Electrical 2019_RUS
There is no option “Remove all child cable markers”.
I can not find the Cablecon files.
Message 12 of 35
galashkina
@rhesusminus, can you help again?
In which folder should the cablecon files be located so that they are displayed in the dialog box?
Message 13 of 35
rhesusminus
Try this one.
Unzip those files in %APPDATA%\Autodesk\AutoCAD Electrical 2019\R23.0\enu\Support\User
Trond Hasse Lie
Ctrl Alt El
Message 14 of 35
galashkina
Thanks, rhesusminus!
You helped again.
Message 15 of 35
galashkina
@rhesusminus , I have problem again in version 2020   Smiley Sad
Message 16 of 35
rhesusminus
I thought I'd told you NOT to update 😉
Try this:
Trond Hasse Lie
Ctrl Alt El
Message 17 of 35
galashkina
Thank you so much again!
Everything worked out!
Message 18 of 35
andron_kozmos
Hello, is there a cablecon2017 version? Or does anyone do that?
Message 19 of 35
galashkina
in reply to: andron_kozmos
Message 20 of 35
andron_kozmos
Tell me again what should be the path for unzipping? I just have three folders in AppData: Local, LocalLow, Roaming.
”Boost
