• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    trvrprtr
    CROSS-REFERENCE ATTRIBUTE 'CONTACT' PERMISSIBLE ENTRIES - "NO-TC"
    71 Views, 1 Replies
    01-31-2012 03:05 PM
    I am trying to have a custom contact appear as a non-standard value  in a Component Cross-Reference Table format.
    Wikihelp says :-
     "CONTACT -  The value of this attribute is the contact's de-energized state (ex: "NO" or "NC" or any text string with an embedded "NO" or "NC" such as "NO-TC".
    I can't get any value to appear in the table other than NO, NONC or NC.  "NULL" does stop the cross-reference appearing.
    Wikihelp gives an example of 'NO-TC' but I can't get this to work for tabular cross-referencing.  Reports are okay.
    Does anyone know any other values that might work?
    Active Member
    trvrprtr
    Re: CROSS-REFERENCE ATTRIBUTE 'CONTACT' PERMISSIBLE ENTRIES - "NO-TC"
    01-31-2012 03:22 PM in reply to: trvrprtr
    I see why now - in the Properties>Drawing Properties>cross-references>Table Format tab there are only the three options.  And under Setup (Cross-reference Table Fields to Display) there doesn't appear to be any way to add a custom field.  Does anyone know of a method of adding extra fields?
