• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Breaker auxiliry contacts & motorized operating mechanizm
    163 Views, 2 Replies
    10-29-2012 08:15 AM
    Please help me to know the proper way of insering NO/NC/Trip auxiliry contacts for a circuit breaker, also I need to add a Undervoltage/ shunt trip release and a motorized electrical operating mechanism for the same breaker. Now Iam choosing a relay NO contact and change the family to CB. I dont know how to show the undervolatge release/shunt trip release/ motorized operating mechanism for that breakers. While making a component wirle list I need to get all the wire connections associated with that particular breaker.
    Rajesh.
    Please use plain text.
    Distinguished Mentor
    Re: Breaker auxiliary contacts & motorized operating mechanizm
    10-29-2012 03:39 PM in reply to: psrajesh4u
    Under the breaker/disconnect menu in the Insert Component dialog, there is a sub menu for Circuit Breaker 2nd poles.
    This includes the standard auxiliary contacts which should cover your contacts.
    However the the shunt trip and and motorised operator are not represented. I actually copied the standard relay coil, modified it to be a child component and stuck it in this menu as well. This coil is what I use for things like the shunt trip. For a motor, go to the Motor Control section and there should be a suitable motor there.
    I find that I use coils like this a fair bit as the company I work for builds and supplies 11kV and 33kV vacuum and gas circuit breakers.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    Re: Breaker auxiliry contacts & motorized operating mechanizm
    10-30-2012 07:44 PM in reply to: psrajesh4u
    Thank you for your reply.
    regards,
    Rajesh.
