AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
BoM updates
- Highlight
- Email to a Friend
- Report Inappropriate Content
Previous help to crerate a BoM was helpful and got me going and it is working.
I now find that there is problem that could be my lack of knowledge or I am trying to do something that ACE will not do.
So here is my question:
I have created a default_cat.mdb by using a supplied library. I edited this library as per the previous BOM help. This has resulted in a default .mdb that is working.
I then make a project specific .MDB and add the componants that are required for that specific project. This is also working.
If I find a mistake in the <project>.mdb I would like to be able to edit the default.mdb and then have the update to the <project>.mdb to happen automatically.
Is this possible? If so how can I achieve this?
Thanks in advance Cheers johnq
Re: BoM updates
- Highlight
- Email to a Friend
SInce I submitted the above enquirie I have worked out how to do what I wanted and it can be done.
If the answer is in the help files then I could not find out how.
Just for interest a few things I have discovered: always up date the default_cat.mdb Always do a save before moving from one drawing to another
Update the <project>_cat.mdb
I had a problem with my computer and I lost access to the default file, this happened at a time when I did not appreciate the relationship between the default_cat.mdb file and the <project>_cat.mdb
cheers john q
Re: BoM updates
- Highlight
- Email to a Friend
There is no concurrent link between the default_cat.mdb file and any project_specific catalog you ay choose to create. When you choose to create a project-specific catalog database Electrical simply interrogates the drawings via the project scratch database and creates a custom catalog database for the project by copying the necessary records from the default_cat.mdb file. It is a one-way process. The best way to propagate a change from the main catalog database is to delete the project-specific catalog database and run the new utility that was introduced with version 2012 that updates components from the catalog database. There is a detailed explanation in the next paragraph. After you update your components just create a new project-specific catalog database.
Version 2012 introduced a utility that can update component symbols with new data from the catalog database. Changes made to the catalog fields for a particular part number can be automatically reflected in the project drawings via a new command on the Project tab. I have included a screen capture from the version 2012 What's New list. Even the TEXT VALUE fields can update. So if I have a TEXT VALUE entry of DESC1=POWER SUPPLY and a later change it in the catalog to DESC1=DC POWER SUPPLY, after I run the Component Update from Catalog utility all symbols with the power supply part number will receive an update to their Description 1 field (DESC1 attribute).
Doug McAlexander
Electrical CAD Industry Specialist
Independent Consultant/Instructor/Mentor
AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
www.ECADConsultant.com
Re: BoM updates
- Highlight
- Email to a Friend
Thanks Doug
