• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Valued Contributor
    johnq
    BoM updates
    114 Views, 3 Replies
    02-01-2012 03:54 PM
    Previous help to crerate a BoM was helpful and got me going and it is working.
    I now find that there is problem that could be my lack of knowledge or I am trying to do something that ACE will not do.
    So here is my question:
    I have created a default_cat.mdb by using a supplied library.    I edited this library as per the previous BOM help.   This has resulted in a default .mdb that is working.
    I then make a project specific .MDB and add the componants that are required for that specific project.   This is also working.
    If I find a mistake in the <project>.mdb I would like to be able to edit the default.mdb and then have the update to  the <project>.mdb to happen automatically.
    Is this possible?  If so how can I achieve this?
    Thanks in advance    Cheers  johnq
    Valued Contributor
    johnq
    Re: BoM updates
    02-02-2012 03:23 PM in reply to: johnq
    SInce I submitted the above enquirie I have worked out how to do what I wanted and it can be done.
    If the answer is in the help files then I could not find out how.
    Just for interest a few things I have discovered:  always up date the default_cat.mdb   Always do a save before moving from one drawing to another
    Update the <project>_cat.mdb
    I had a problem with my computer and I lost access to the default file,  this happened at a time when I did not appreciate the relationship between the default_cat.mdb  file and the  <project>_cat.mdb
    cheers  john q
    *Pro
    Re: BoM updates
    02-03-2012 07:09 AM in reply to: johnq
    There is no concurrent link between the default_cat.mdb file and any project_specific catalog you ay choose to create.  When you choose to create a project-specific catalog database Electrical simply interrogates the drawings via the project scratch database and creates a custom catalog database for the project by copying the necessary records from the default_cat.mdb file.  It is a one-way process.  The best way to propagate a change from the main catalog database is to delete the project-specific catalog database and run the new utility that was introduced with version 2012 that updates components from the catalog database.  There is a detailed explanation in the next paragraph.  After you update your components just create a new project-specific catalog database.
    Version 2012 introduced a utility that can update component symbols with new data from the catalog database.  Changes made to the catalog fields for a particular part number can be automatically reflected in the project drawings via a new command on the Project tab.  I have included a screen capture from the version 2012 What's New list.  Even the TEXT VALUE fields can update.  So if I have a TEXT VALUE entry of DESC1=POWER SUPPLY and a later change it in the catalog to DESC1=DC POWER SUPPLY, after I run the Component Update from Catalog utility all symbols with the power supply part number will receive an update to their Description 1 field (DESC1 attribute).
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    www.ECADConsultant.com
    Valued Contributor
    johnq
    Re: BoM updates
    02-06-2012 04:48 PM in reply to: dougmcalexander
    Thanks Doug
