• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    johnq
    BoM updates one more time
    41 Views, 1 Replies
    02-02-2012 03:28 PM
    Is there a way to copy a record on the default_cat.mdb file from one family to another family?
    cheers  johnq
    Valued Mentor
    Re: BoM updates one more time
    02-02-2012 04:06 PM in reply to: johnq
    When you say FAMILY, do you the brand or the type of component?
    If it's the brand or manufacturer, in the catalog lookup dialog, go to the original entry, click once on the entry to highlight it. Now click the ADD button. Change the manufacturer and click ok.
    If you mean the type of component, you will need Microsoft Access to do it quickly and cleanly.
    Make sure you know the code for the original and new locations. (IE CR used to mean Relay, PB used to mean pushbutton)
    Go to the table used for the original entry and find said entry in the table.
    Highlight the row of the entry you want to copy, go to the EDIT drop down and select COPY.
    Now go to the table for the new entry, scroll down to the bottom and click to highligh the row with the star. Select PASTE from the edit drop down and you are done.
    Just make sure to SAVE before closing Access.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
