• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Member
    magic_al
    Big Components
    131 Views, 3 Replies
    11-10-2011 07:26 AM
    This is my first posting and hopefully it will be easy to solve.
    When I create a new drawing, I use the ACADELECTRICAL template as instructed by the autodesk tutorial but when I place a component or a ladder they are huge.
    I'm using AutoCAD Electrical 2006
    Thanks in advance
    Alan
    Please use plain text.
    Member
    magic_al
    Re: Big Components
    11-11-2011 12:51 AM in reply to: magic_al
    I've managed to get everything to a 'normal size apart from dot tee markers???
    Distinguished Mentor
    Re: Big Components
    11-13-2011 06:31 PM in reply to: magic_al
    It sounds like you have inserted imperial symbols on a metric template.
    Try this to see if it is the problem.
    Start a new project using the same settings as before.
    Right click on the project name in the Project Manager and go to Properties.
    Under the Project Settings tab, click the plus sign next to Schematic Libraries
    Click on the first entry under Schematic Libraries and then click on Add on the right
    Now click once on the new entry, and then using the Move Up button on the right move it to the top of the list.
    Click on Browse and then change the directory to the IEC2 sub-directory under the blocks directory.
    Click OK and then add a new dwg to the project.
    Now try inserting a component.
    If it comes in at the proper scale, your project is looking in the wrong directory. If it's a little small, you may need to use the IEC4 sub-directory instead.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    Member
    magic_al
    Re: Big Components
    11-24-2011 02:23 AM in reply to: Icemanau
    Thanks for the reply but AutoCAD Electrical 2006 doesn't have anything relating to schematic libraries when I go to project properties. I have since found a template that works fine so it's no longer a problem
