• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    Bad argument error during surf from Panel
    67 Views, 2 Replies
    09-01-2004 04:22 AM
    When surfing from the panel layout in my project, I can surf to up to 5 items, then the surf dialog closes down with the following error message:
    Command: wd_surf_exc_zoom_in_oem "278" "2" "C:/Documents and
    Settings/user/Application Data/Autodesk/AutoCAD Electrical
    2005/R16.1/enu/Support/user/PNLXCPT.GO2" nil nil nil ""
    Error: bad argument type: stringp 01/
    I've duplicated the error 3 times, and in all cases, the maximum number of items to surf prior to bombing out is 5.
    Suggestions?
    Please use plain text.
    *Nate Holt \(Autodesk\)
    Re: Bad argument error during surf from Panel
    09-01-2004 05:35 AM in reply to: tfite
    Can you zip and email me your project? Send to nate.holt@autodesk.com and identify which dwg and component tag you're starting from. "tfite" wrote in message news:29222269.1094037768999.JavaMail.jive@jiveforum1.autodesk.com... > When surfing from the panel layout in my project, I can surf to up to 5 items, then the surf dialog closes down with the following error message: > > Command: wd_surf_exc_zoom_in_oem "278" "2" "C:/Documents and > > Settings/user/Application Data/Autodesk/AutoCAD Electrical > > 2005/R16.1/enu/Support/user/PNLXCPT.GO2" nil nil nil "" > > Error: bad argument type: stringp 01/ > > I've duplicated the error 3 times, and in all cases, the maximum number of items to surf prior to bombing out is 5. > > Suggestions?
    09-02-2004 06:46 AM in reply to: tfite
    Okay, we have duplicated the problem. Will log the issue and attempt to resolve. Thanks for the report!
