• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Distinguished Contributor
    april_herr
    Accepted Solution
    BOM
    131 Views, 3 Replies
    02-06-2012 11:33 AM
    When I run my BOM report, how do I get it into sequential order?
    Thanks!
    April  :cathappy:
    Valued Mentor
    Re: BOM
    02-06-2012 07:10 PM in reply to: april_herr
    Once the report has been generated and is on screen, you click on the sort button (lower right had section in ACADE 2008). Choose which fields you want to sort by and there you go.
    You do need to do this before you export to a file or putting it on a dwg though.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    april_herr
    Re: BOM
    02-11-2012 06:18 AM in reply to: Icemanau
    Thank you very much!  Sometimes the solution is so simple...
    april_herr
    Re: BOM
    02-11-2012 07:20 AM in reply to: Icemanau
    One more question relating to the BOM:
    I have a panel layout that I have put my balloons on, but on my BOM, the enclosure and one of my modules are the same item number.  When I try to redo the balloons, each part comes up as item one.  My encl is supposed to be item 15, but when I edit attribute on the encl balloon, my BOM doesn't change.  Any ideas?
    Thanks!  April
