• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Member
    ASI_BSD
    BOM Reports Effected by Tags
    120 Views, 1 Replies
    01-30-2012 06:28 AM
    When I create a BOM Report of a panel everything looks correct, but when I create a BOM Report of the entire drawing, it doesn't look the same. Could tags be affecting this?
    BSD Technical Support
    AdvancedSolutions.com
    "You may not be able to erase your past, but you are the artist of your future!"
    Please use plain text.
    Distinguished Mentor
    Re: BOM Reports Effected by Tags
    01-31-2012 10:16 PM in reply to: ASI_BSD
    Most obvious question but are you using the same report methods and format.
    There may be differences between the schematic and panel reports and the BOM format for each may also be different.
    Plus you also have the various types of BOM reports to choose from.
    As a test, try to run the two reports again. Make notes on which type of reports, format and so on you are using for the first one. Run the second report using same settings from the first report and see if anything changes.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
