AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Automatic wire tagging not tagging all wires?
- Highlight
- Email to a Friend
Hello
I'm fairly new to autodesk, I have tried the drawing wide auto wire tag and it doesn't seem to be tagging all of the wires any suggestions from you guys why it might be doing this?
Any help appreciated
Cheers
Peter
Re: Automatic wire tagging not tagging all wires?
- Highlight
- Email to a Friend
Be sure that the terminal block symbols on those un-numbered wires are of the type to force a wire number change. It appears that you prefer to assign a different wire number to field wires. You must force the wire number change by using a terminal or connector that changes the wire number as it passes through. Hint: This type of terminal or connector must also be used if your field wires are set for no wire numbering.
Doug McAlexander
Electrical CAD Industry Specialist
Independent Consultant/Instructor/Mentor
AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
Web site: www.ECADConsultant.com
E-mail: ECADConsultant@gmail.com
Phone: (770) 841-8009
- Highlight
- Email to a Friend
Also check that your wire layers are able to be numbered. Type AEWIRETYPE in ther command line and make sure that the wire numbering box for the wire layer that you are trying number has "YES" in it.
