• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    adrien.levasseur
    Automatic Title Block ACE 2009
    365 Views, 2 Replies
    12-07-2011 01:31 PM
    Hi everybody,
    I'd like to impose a common automated title block* in my company. I use the WD_TB invisible attribute method. I made it work very well with ACE2010 doing it this way :
    1. Create New drawing
    2. Editing block : ACADE_TITLE
    3. Creating each attribute such as SH, SHM, DRAWNBY...
    4. Creating the invisible WD_TB attribute, giving him the value such as "SH = SHEET;SHM = SHEETMAX;DRAWNBY = LINE2 etc..."
    5. Save and close this block
    6. Insert the block on the drawing
    7. Save as "ACE_PFD_{*Version number*}.dwt"
    When i use this procedure and create a drawing within any project and using ACE 2010, it works very well
    But it does'nt work at all in (my) ACE2009. When i try to "update the title block*" (right click on project folder*) it can find the WD_TB attribute, but it says "cannot find SHEET attribute, cannot find LINE1 attribute..." and so on even if i try to configure the WD_TB attribute through the editor (project -> Configure title block*).
    I send you my file to let you check what is wrong inside it.
    Thanks for any help to come :smileywink:
    *Sorry if translating is not good, i have french version, and i tried to guess the commands
    Please use plain text.
    Distinguished Mentor
    rhesusminus
    Re: Automatic Title Block ACE 2009
    12-08-2011 01:14 AM in reply to: adrien.levasseur
    Hi.
    This isn't helpful in any way, but I just tried to open your ACE_PFD_V0_20111206_ACAD2007.dwg in a copy of AcadE 2009 I have here. Apart from the WD_M block missing, the titleblock updated as expected.
    THL
    THL
    Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
    adrien.levasseur
    12-09-2011 05:46 AM in reply to: rhesusminus
    Thanks for your "help". This would at least show my drawing was good.
    Actually, i created a new .dwt file with the exact same title block "acade_title". But i used the WD_TB editor. It is working now.
