• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    New Member
    jtebright
    Autocad Electrical 2013 Fatal Error on Load
    163 Views, 1 Replies
    01-23-2013 10:12 AM
    When I try to open Acade 2013 I get:
    Fatal Error: Unhandled Access Violation Writing 0x0000 Exception at oh
    I cannot find any topics on this or how to resolve it.
    Please use plain text.
    Distinguished Contributor
    Re: Autocad Electrical 2013 Fatal Error on Load
    01-23-2013 01:23 PM in reply to: jtebright
    Hi JTEBright,
    I have a few things you can try;
    1. Turn the User Account Controls [UAC] off, and remove any user restrictions on file folders that ACADE Accesses
    2. Try logging in as a second user on the machine (see if the new user has the same issue)
    if the other user has the same issue than its not user based.
    if it does work with the new user, blow away the AutoCAD Electrical 2013 file folder located in:
    C:\Users\<user name>\AppData\Roaming\Autodesk\AutoCAD Electrical 2013
    3. try installing the lastest SP
    http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240738
    4. run a repair on the installation (requires the media)
    5. (last resort) Re-install ACADE 2013 from working media (usb, dvd, etc)
    I hope this helps,
    James Alger
    Solidcad
