• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    AutoCad Electrical and PDM
    193 Views, 2 Replies
    10-03-2003 12:16 AM
    Is anyone aware of the best way to utilize a PDM System with AutoCAD Electrical. Should we be checking out all of the drawings in a project or just one at a time. Any help on this would be greatly appreciated.
    Please use plain text.
    *Holt, Nate
    Re: AutoCad Electrical and PDM
    10-03-2003 09:38 AM in reply to: rstein546
    AutoCAD Electrical 2004 uses a "project" concept to
    pull together a collection of one to hundreds of interrelated schematic, panel,
    wiring diagram drawings together. Each project is given a name and is
    represented by a small ascii text file that lists all of the different AutoCAD
    drawings that are to be treated as a single project set for component
    tagging, cross-referencing, wire numbering, and BOM report generation.
    For these inter-drawing functions to fully work,
    AutoCAD Electrical needs to be able to access the complete drawing set.
    Therefore, with a PDM system, instead of checking out individual
    drawing documents, you would probably want to check out a project
    set.
    Re:
    10-04-2003 10:22 AM in reply to: rstein546
    Thanks Nate, That is what I thought. Just wanted to verify.
