• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Member
    AutoCAD Electrical, Contractor Symbol ?
    504 Views, 7 Replies
    02-22-2013 04:01 AM
    Hi All,
    Ive been searching the net for this for hours now and im just wondering if im being stupid in thinking there is a AutoCAD Electrical symbol for a 3 phase contactor or do you have to put 3 seperate contacts in and parent them to a contactor coil?
    I'm running AutoCAD Electrical 2011.
    I hope im not being stupid and the anwser is in front of me.
    If anyone can help ive appreciate it.
    Please use plain text.
    Valued Contributor
    Nata_ly
    Re: AutoCAD Electrical, Contractor Symbol ?
    02-22-2013 04:26 AM in reply to: amason88
    Hi!
    Is it in a Motor Control menu?
    Member
    02-22-2013 04:44 AM in reply to: Nata_ly
    There's one called motor start 3 pole, but i was always led to believe it was a different symbol than the one shown on that?
    *Expert Elite*
    02-22-2013 05:26 AM in reply to: amason88
    Contactors and motor starters are used interchangeably.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    *Expert Elite*
    02-22-2013 05:28 AM in reply to: amason88
    That is the one to use for a motor contactor (3 Phase Starter Contacts NO). It is built dynamically from 3 NO/ contacts (HMS21) and then joined with a link line.Then you add the Starter coil as a parent and link it to the contacts.
    Bob Hanrahan
    Ace User since 1998
    Member
    02-22-2013 05:39 AM in reply to: testsubject
    Thanks alot guys, im all sorted now.
    Cheers :smileyhappy:
    RePao
    02-24-2013 04:26 AM in reply to: amason88
    We are working with AutoCAD ecscad in D-A-CH and there of course exist symbols like MAINCONTAKTS with 3 NO in one Block. I'am not really sure, but I mean that in electrical you can only place 3 single NO to one, (hide DID and so on, will be useful) Regards Ren?
    stay tuned &
    Greetings from Switzerland
    *Expert Elite*
    02-25-2013 05:20 AM in reply to: RePao
    I use ecscad and AutoCAD Electrical.  The difference is that with ecscad, just like all other electrical CAD software, you must create a symbol for 1 contact, 2 contact, 3 contact, etc.  AutoCAD Electrical builds the contacts dynamically by inserting multiple 1 pole contacts and combining them with a dashed link line to indicate they are activated together by the same coil, button, or selector. This method allows the software to insert the symbol across any wire spacing.  If you wish to add a 4th contact, go to the menu for that type of symbol and look for a 2nd+ or 2+ type of symbol.  This is used to add additional contacts to an existing symbol.
    Doug McAlexander
