• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Member
    JEeten
    AutoCAD Electrical 2013 Icon menu problem?
    932 Views, 7 Replies
    03-29-2012 06:05 AM
    Hi all,
    I have Electrical 2013 installed on win7 64x.
    The following problem: I insert a pushbutton via the icon menu. Then I insert a Hydraulic component with "Insert hydraulic component". So far so good.
    But then I click again on Icon Menu to insert another Pushbutton, then the Hydraulic Icon menu appears.
    I can't get into the normal electric components icon menu. Then I have to restart Electrical 2013 to have the normal Icon menu back. But when I use the other Icon menu's (Pneu, Hydr, PID) then I don;t get the normal icon menu.
    Has anybody else this problem?
    John
    Please use plain text.
    Active Contributor
    Re: AutoCAD Electrical 2013 Icon menu problem?
    03-30-2012 01:21 PM in reply to: JEeten
    I have experienced the exact same issue.  Autodesk please fix, I anticipate this shouldn’t be a significantly large problem, however, I can foresee times when it will be very annoying.
    Employee
    mathalekar
    04-01-2012 09:13 AM in reply to: DBrohm
    I tried to validate this issue on ACADE 2013 but was not able to reproduce this at my end. Can you send me details of your steps on my official id mayuresh.athalekar@autodesk.com ?
    Thanks & Regards,
    Mayuresh Athalekar
    Employee
    mathalekar
    04-01-2012 08:59 PM in reply to: JEeten
    After doing further investigation i could reproduce this issue at my end as well. We have noted this issue at our end. Thanks for reporting.
    Thanks & Regards,
    Mayuresh Athalekar
    Employee
    mathalekar
    04-02-2012 09:01 PM in reply to: JEeten
    Here is a quick solution in which user need not to exit the application.
    1. When you switch to Hydraulic / Pneumatic icon menu and want to insert the default standard icon menu (instead of closing the application) go to Icon Menu wizard via Components >Symbol Library > Icon Menu Wizard or use command “AEMENUWIZ” command to invoke Icon Menu wizard.
    2. ACADE displays default DAT file used for the project (ACE_IEC_MENU.DAT or ACE_JIC_MENU.DAT). Simply click on Cancel button in the dialog box.
    3. Invoke Insert Component feature, ACADE starts showing default Icon menu.
    We have noted this issue and working on it. But this at least resolves the issue (I understand there is a small steps to perform by user) and user need not to exit application.
    Thanks & Regards,
    Mayuresh Athalekar
    Distinguished Contributor
    05-23-2012 11:36 PM in reply to: JEeten
    When is the SP available for this bug? This icon menu freezing is very annoying...
    /mako
    New Member
    01-08-2013 10:25 AM in reply to: JEeten
    Has this bug been fixed?
    I have AutoCAD Electrical 2013 Version 10.0.47.1
    Employee
    mathalekar
    01-08-2013 07:35 PM in reply to: dalebra
    The version 10.047.1 is hotfix version for snap issue that we had released. Please apply service pack 1 for 2013 release via autodesk website. You can apply update the same within product via Product update check in top right corner icon. With application of Service pack we have integrated the fix for icon menu. The product version after application of service pack is going to be 10.1.0.7.
    Thanks & Regards,
    Mayuresh Athalekar
