AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: AutoCAD Electrical 2012
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi there,
First of all I am not sure if this was mentioned previously, sorry in advance if it was.
I am encountering issues with selecting multiple files (using the Shift key) when adding drawings into a project. I am using 2012 Electrical+SP1 on Windows 7. I have no issues when using the Control key but it takes forever...Basically Autocad hangs when I try to select multiple drawings using the Shift Key.
Thanks in advance!
Stefan
- Highlight
- Email to a Friend
I tried the Hotfix and was not able to start AutoCADE after following the directions. Attached is the error that I got. Any suggestions?
- Highlight
- Email to a Friend
I will forward this error image to support. Did you install the hotfix for 32 bit or 64 bit system? What operating system are you on?
In the meantime the readme has these instructions for installing and removing the hotfix -
- Exit AutoCAD Electrical
- Download the appropriate hotfix
- For 32 bit operating systems - DL16822624.zip
- For 64 bit operating systems - DL16822624_x64.zip
- Find the product installation folder; for example C:\Program Files\Autodesk\Acade 2012.
- In this folder, right-click the acad.exe file and select Properties.
- In Windows XP, click the Version tab, in Windows Vista or Windows 7 click the Details tab. Confirm the file version.
- If this file is version 24.2.51.0, then proceed with this installation.
- If this file is version 24.2.51.2, then this hotfix has already been applied.
- Goto product installation folder, right click on "acad.exe" and rename it to "acad.bak" to retain the original file as backup.
- Double-click the downloaded file.
- Extract acad.exe to the product installation folder (for example, C:\Program Files\Autodesk\Acade 2012)
- Verify the version of the replaced file by right-clicking on the new acad.exe file and select Properties. In Windows XP click the Version tab, in Windows Vista or Windows 7 click the Details tab. Confirm this file is version 24.2.51.2.
NOTE: To remove this HOTFIX, delete the new acad.exe file and the rename the file acad.bak back to its original name of acad.exe.
Pat Murnen
AutoCAD Electrical Subject Matter Expert/Writer
Manufacturing Learning Experience
Autodesk, Inc.
- Highlight
- Email to a Friend
I am running WinXP 64bit and the directions that you posted from the readme are the same steps that I followed when doing the hotfix. I made sure to download the 64bit version. and still got the error that I posted.
- Highlight
- Email to a Friend
I am passing this information on to support but in the meantime I just wanted to make sure you could uninstall it (text in red about renaming the backup file made when installed) and run AcadE.
If you are a subscription customer I would recommend logging this through that route as well. I checked to see if there were issues already logged regarding this hotfix but didn't find any.
Pat Murnen
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi gtralt,
Have you patch the SP1 into your ACE2012 alrealy before you patch the Hotfix?
I can reproduce your issue if I patch the SP1 to the ACE2012 firstly, then patch the hotfix again.
If you have patch the SP1 for ACE2012, then you don't need to patch this hotfix again. As we release the hotfix firstly, then release SP1. So in the SP1, it includes the hotfix for the snap issue, please check the SP1 readme for detail.
So now please follow the Note below to remove the HOTFIX, then you should can launch the ACE with no issue. and also the snap issue is fixed by the SP1.
Please let me know if you still encounter issues.
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
- Highlight
- Email to a Friend
Yes, I do have SP1 installed for AutoCADE 2012. So I'm good to go. I removed the hotfix and continued on business as usual.
Greg
