• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    Re: AutoCAD Electrical 2012
    04-12-2011 08:37 AM in reply to: KevinLi-Autodesk
    Kevin,
    I installed the hotfix this morning. So far, so good. I appreciate your attention to this issue.
    David Brude
    Please use plain text.
    JCard
    04-12-2011 06:49 PM in reply to: KevinLi-Autodesk
    Thank you Kevin for the hotfix.  Applied in a 'snap' !  Thanks for listening and the quick fix.
    JCard
    McKee Foods Corp.
    Design Drafter
    Active Member
    post
    04-14-2011 12:34 AM in reply to: david_brude
    The snap works only if you select a command. How can i turn it on permanent , like before, so i dont need to activate a command to check if a customer drawing is in snap or not?
    Employee
    04-14-2011 01:23 AM in reply to: post
    I need to clarify the scope for this hotfix, it will not fully revert back the behavior to old AcadE2011, it restores snap behavior during netsel/nentsel/nentselp operations based on AcadE domain customer experience. We do not change the cursor movement behavior with this fix, so when no command is active, the cursor moves freely regardless of SNAPMODE and this is actually an enhancement by AutoCAD 2012 Team.
    Kevin Li
    Active Member
    post
    04-14-2011 05:00 AM in reply to: KevinLi-Autodesk
    Ok, then we just continue to use AcadE 2011. For me and my collegues, this new snap is just extreme irritating, and it should be an option if we customers want this snap behaviour or not.
    Active Member
    05-13-2011 11:51 AM in reply to: DBrohm
    I started using AutoCAD in April of 1984 on a machine with 8" floppy discs and a CPM86 operating system.  Snap has worked the same way since then, UNTIL NOW.  WHY???  How difficult can it be to provide snap with three options, OFF -- "PART TIME" -- FULL TIME?  Let those who want to use it "part time" do so and let those who want to use snap full time do so.  What is so difficult about that?  If Autodesk wanted to, one of their "smart" programmers could do this in a half an hour or less.  It would stop all the bitching and restore faith in the product.  Maybe Autodesk just wants to see how much aggravation they can cause in the workplace while raking in all the subscription fees.  I asked for a full description of how snap is now working through "feedback" some time ago and never received a responce.
    Employee
    05-18-2011 07:25 AM in reply to: john.mckay
    The current snap behavior works like this -
    If no command is running the snap is not active.
    If you are running a command and you are selecting components the snap is not active. This is seen as an improvement because many times when you are trying to select a component and the snap is active it is difficult to select right on the component.
    If you are running a command and you are selecting a location, the snap is active.
    In AutoCAD Electrical there are some commands that your one selection is used for BOTH selecting an object and a location at the same time, for example the multiple bus command. The hotfix supplied addresses these situations so that during these selections the snap is now active.
    Pat Murnen
    Principal Content Developer
    Information Modeling and Platform Products Group
    Autodesk, Inc.
    *Expert Elite*
    05-18-2011 11:57 PM in reply to: murnenp
    Hi Pat!  Great explanation!  I like the new snap function, after the patch.  It is convenient that the snap stays off until I invoke a command.  It does make it easier to select smaller drawing elements for edits or moves.  Yet when I click to insert a wire, the snap engages according to the snap settings I have set.  I can see that this is intended as an improvement.  With previous versions I would find myself needing to manually turn off snap to select a drawing element and then turn snap on again so I could execute a move and remain on the grid.
    I do see where some customers could become frustrated, if they are trying to use Electrical for a mechanical drafting task that requires a constant snap function.  Perhaps there needs to be a toggle to allow us to disengage this new snap behavior when not desired.  For example, when Dynamic Input was first added, it annoyed me.  I would immediately turn it off when I started Electrical.  Now it defaults to off and that is good for me, since I am not a fan of Dynamic Input.  But for those who prefer Dynamic Input, they have the opportunity to toggle it on.
    I would hate to see this new snap behavior eliminated altogether but I think there should be a toggle to turn it on or off according to user preference.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    Employee
    05-19-2011 04:14 AM in reply to: dougmcalexander
    Doug,
    I meant to add to my explanation that we do understand now the need for a switch or system variable so you can control this a little more. This has been logged.
    Sorry for any inconvenience,
    Pat
    Pat Murnen
    Autodesk, Inc.
    Active Member
    05-19-2011 07:07 AM in reply to: DBrohm
    Doug and Pat seem to put in some long hours (11:57 & 04:14)!  Is late-night e-mail sending is good for insomnia?
    I thank you both for the SNAP explanation, originally requested from "Feedback" on 04Apr.  I agree that with the hotfix, ACADE2012 functions a lot better.  As stated earlier, I do everything on snap and have always used the crosshairs to locate things via the coordinate window.  Some of my drawings visually continue (line up) on to other drawings, so alignment is critical.  Without "full time" snap, I have to enter the Line command to activate snap and get the coordinates.  I agree the "new" snap has a lot of benefits as many times I have to toggle F9 (snap) in order to select an object.  As for structural switchgear enclosures designed in ACAD (in millimeters and ON SNAP), I will continue to use ACAD2011 as without full time snap I just can not function in ACAD2012.
    Pat stated that "this has been logged".  Does that mean to be fixed, as in perhaps a toggle, OFF / PART TIME / FULL TIME?
    I wonder just how much productive time has been lost among all the users of ACAD and its various versions over this changed snap function.  From the comments I have seen posted, most everyone thought it was broken.  An upfront explanation of this feature in WHAT'S NEW certainly would have saved a lot of angst.  Why was a feature change such as this a SURPRISE?  Perhaps eventually time may be saved with this feature as in many cases object selection may become easier.
    JDM
