• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    AutoCAD 2013 Issue with Title Block Update
    654 Views, 4 Replies
    07-02-2012 12:00 PM
    Hello, I have an issue when I am working with ACADE 2013, when I try to use Title Block Update, ACADE freeze itself, but when I press ESC key ends the command, I attach a image related about what I am doing, I did the ACADE 2013 tutorial, and then when I do step 6, it freezes.
    Please use plain text.
    Distinguished Mentor
    Re: AutoCAD 2013 Issue with Title Block Update
    07-02-2012 03:31 PM in reply to: JavZaMa
    From the sounds of it, you have somehow got the dialog box opening up off screen.
    I can't recall how to rectify that offhand, but you could try increasing your screen resolution temporarily and moving the dialog to a area over the acad window before resizing to what you had.
    You could also try hooking up a second monitor (I actually recommend this as standard). This gives you a second screen where you can have your toolbars sit and give you more screen area for your dwg.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    07-02-2012 03:41 PM in reply to: Icemanau
    Hi, I was working with a second monitor, what I do not know if even this way that dialog box is off screen
    Employee
    RobinShou-Autodesk
    07-02-2012 10:47 PM in reply to: JavZaMa
    Would you please check this post? there is a workaround in the post for this dual monitor issue for ACE2013 now. We are considering a fix for this issue now.
    http://forums.autodesk.com/t5/AutoCAD-Electrical/Suddenly-cannot-peform-batch-plot-or-title-block-up...
    Robin Shou
    Quality Assurance
    AutoCAD Electrical
    07-03-2012 07:05 AM in reply to: RobinShou-Autodesk
    Oh thank you so much, it fixed the issue, yei !
