• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Valued Contributor
    Auto save AcadE 2012 does not work
    230 Views, 5 Replies
    01-20-2012 02:07 AM
    I deleted 50,000 files from the temp to empty it a bit.
    with acad e 2012 on w7
    in the options :
      file safety precautions
      -automatic save 10 or 2  or 1 minutes between saves
      -file extention for temporary files
       ac$
      automaic save file location
      c:\users\username\appdata\local\temp\
    in this location are :
      ace script files
      1 undo.ac$
    a few :
      tmp
      cvr
      mdb
      lsp
    files
    but no opend dwg files *.ac$
    Is autosave working for sombody with acade2010 ?
    Valued Contributor
    Re: Auto save AcadE 2012 does not work
    01-20-2012 03:56 AM in reply to: Wheelie22
    When i have a drawing open there is a :
      dwgname-_1_1_8660.sv$
    file there but no ac$ !
    Valued Contributor
    johnq
    01-29-2012 08:02 PM in reply to: Wheelie22
    G'day
    Just a thought:    I have been caught when IT folks install ACE and do not know how to configure it.
    Has the path been set in ACE/AC?   (tools   open/save)  IT may want the temp location on a server so the server path needs to be set in the mentioned files.
    I have often needed to created the directory for these files.
    I believe that the .bak file is only created when a file is closed.
    Hope this helps.
    John Q
    Valued Contributor
    01-29-2012 11:26 PM in reply to: Wheelie22
    Here are my options Open/Save
    I used the extension qqe just to test, but no qqe files in the temp.
    The automatic save path is :
       C:\Users\USERNAME\appdata\local\temp\
    And the bak file is normally only in the directory where your dwg is, but now it saves it here to.
    But John Q why do a auto save on the network, as you see we use a local profile, and the IT dudes want as less traffic as possible.
    Valued Mentor
    01-31-2012 10:02 PM in reply to: Wheelie22
    One thing to keep in mind.
    The AUTOSAVE file are only kept until you save the dwgs you have open or close the dwg without saving.
    At that time, they are automatically deleted.
    I've been caught by that, had autosave on and made some changes. Went to close the dwg and hit NO to the save question by mistake. Unfortuanetly I couldn't use the autosave file to recover the work as it was automatically deleted.
    About the only time you would be able to use the autosave file would be if the computer lost power suddenly and there were autosave files in existance for the dwg you are working on.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
    Valued Contributor
    johnq
    02-01-2012 01:35 PM in reply to: Icemanau
    Hi Wheelie
    There has been a lack of communication between my brain and fingers.
    The hidded function I did not mention is  where I have worked my "C" drive does not get backed up.  All drawings and backups are on the server while the software is on the "C" drive.
    I ponder if this is the key to ACE being unstable where I have worked?
    There are critical folders in ACE that I do a manual copy to a directory on the server so that I can recover if necessdar.
    As I understand:   the .sc$ files are also saved to where ever the path is in the FILE set up in AC
    Hope this clears up my previously cripitic  HELP!
    Cheers  jq
