• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Accepted Solution
    Attribute XnPINn
    270 Views, 4 Replies
    10-10-2012 02:26 AM
    Terminal block with the number HT0002 contains attributes X2PIN01, X4PIN01, X1PIN01, X8PIN01. The note did not find any information about these attributes. What are they used?
    Please use plain text.
    *Expert Elite*
    Re: Attribute XnPINn
    10-10-2012 07:40 AM in reply to: galashkina
    In IEC, you not only assign a Terminal number to each Terminal (including each level in a 2/3 level terminal block) but you also can assign a nunber to each side of the terminal. Thiat information is be stored in the X#PIN## attribute.
    For example, say we assign the top screw of a terminal (we will call this TB10)  to 1 (X2PIN01=1) and the bottom to 2 (X8PIN01=2).
    Then, when running a To/From report, it would report a wire connected to the top of the terminal block to TB10.1 and to the bottom TB10.2.
    This allows the designer to be very specific as to where a wire is landed on the terminal. (Since you can draw the schematic so that it depicts exactly how the system is wired.)
    Also, the X# value represents its position on the block
    X1 is Right.
    X2 is Top
    X4 is Left
    X8 is Bottom.
    Bob Hanrahan
    Ace User since 1998
    10-11-2012 02:22 AM in reply to: testsubject
    For example, terminal XT1 1 has two levels: top and bottom (pic1), pin numbers 1, 2, 3, 4.
    These pin numbers are not the values of the attributes of the block terminals NT0002 (pic2).
    Can I display the pin numbers in the drawing and report?
    *Expert Elite*
    10-11-2012 03:59 AM in reply to: galashkina
    Can you post the image of pic2. I do not see it.
    Bob Hanrahan
    Ace User since 1998
    10-11-2012 04:41 AM in reply to: galashkina
    I've had problems with attachment figures.
    I have two signs made one
    pic1=pic1+pic2
