• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    Assign wire colour & wire Guage for specific size of motor
    171 Views, 3 Replies
    02-07-2013 01:28 AM
    In Circuit Builder using marker block How to assign wire colour & wire Guage for specific size of the motor Power circuit & Nested Circuit(Control Circuit).
    Please use plain text.
    *Expert Elite*
    Re: Assign wire colour & wire Guage for specific size of motor
    02-07-2013 06:40 AM in reply to: laki.anu87
    The Wire Color and Gauge is derived from the wire layer. This is assigned by creating a Code (like WT01) that has something like this in the command list.
    (c:ace_cb_set_wiretype #data 1 0 "_WIRETYPE=BU_1.0MM^2")
    Now when you place the marker block on the wire in circuit builder, during the build that wire will be moved to the layer that is stored in WIRETYPE.
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    02-08-2013 04:43 AM in reply to: testsubject
    Thank you for your reply.
    In nested circuit(control circuit) i am not able to insert WHT_10AWG guage wire after overload NC & LTE-10 light. Red_8AWG guage wire run in total nested circuit.
    Please help me how to reslove this issue.
    Attached dwg & spread sheet.In spread sheet-sheet name:3ph_H custome(Highlite in Red colour)
    Active Contributor
    02-11-2013 01:01 AM in reply to: laki.anu87
    Ignore Previous mail.
