AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Active catalog lookup, revisited
- Highlight
- Email to a Friend
- Report Inappropriate Content
I understand this has been addressed, and by all accounts, it shoudl have worked. The problem is, that it didn't and I don't quite understand why it isn't.
My issue: I am trying to establish a network location for the default_cat.mdb file. I have it copied over to a network folder. I go into 'options' and point a new path to that location, move it to the top, hit apply/close. It shows up in the 'options', but it doesn't show up in the project 'current settings'. It still shows the original file location. I ended up creating it as a secondary location, but I would prefer to not do that, as I would like the network location to be the default/standard.
Any suggestions on what i might be doing wrong, or what i am missing?
Thanks for any help
Doug R
Re: Active catalog lookup, revisited
- Highlight
- Email to a Friend
You will need to modify the wd.env file and point it to the new location. This wd.env file is located here in Windows 7 for AE 2013: C:\Users\UserName\Documents\Acade 2013\AeData.
- Highlight
- Email to a Friend
I opened the .env file and find nothing in there to reference what I am trying to fix (I am running 2012, btw). That's not say the information doesn't exist (obviously it does) I'm just unsure what I am looking for. It seems the file is loaded with remarks, with only a few lines of actual code.
- Highlight
- Email to a Friend
Your original wd.env file should have something like this line:
WD_LIB,%SL_DIR%/jic125;%SL_DIR%/jic125/1-;%SL_DIR%
You will need to modify it to the new locations, something like this:
WD_LIB,Y:/Path/Libs/jic125;Y:/Path/Libs/McRae;Y:\P
- Highlight
- Email to a Friend
That did it. Thanks for the help. It took awhile to find the line. It was buried in amoungst all those remarks.
- Highlight
- Email to a Friend
