AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
ACE2012 Link components & reverse component
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi
What is the right way to unlink component
I have reversed the component and then I wasn't able to connect wire,
the connection was made over component, what I make wrong
Thank for help, Vito
Re: ACE2012 Link components & reverse component
- Highlight
- Email to a Friend
How did you reverse the component? If you simply mirrored it, then ACE will not work properly. You have to use the "Reverse/Flip Component"Command. One way of finding it is to hover over the component and then Right Mouse Click. This command is located near the bottom.
You can use "Trim WIre" to disconnect a component from the wiring.
Ace User since 1998
- Highlight
- Email to a Friend
Hi, I used "Reverse/Flip Component" and result is in attachment
block is VSS21 and VSS113
Thanks, Vito
- Highlight
- Email to a Friend
Can you send the .dwg file? I cannot see how the symbol is created done from a jpeg...
Ace User since 1998
- Highlight
- Email to a Friend
Also what library are you using? IEC2, IEC4, JIC1, JIC125, etc? They all use the same file names but the drawings are different.
Ace User since 1998
- Highlight
- Email to a Friend
I use IEC60617 and ACE 2013
- Highlight
- Email to a Friend
I am not sure what is wrong.
I had no trouble reversing any of these contacts.
Sorry that I could be of more help.
Ace User since 1998
- Highlight
- Email to a Friend
When you reversed the contacts, did you check the box to only reverse the graphics?
I've had similar problems in the past when reversing a component and found that if I didn't check that box, the attributes would also be moved but the wire direction wouldn't change.
Regards Brad
You may recognize me from the
hundreds of previous newsreader posts
I've made over the last 5 years
as Brad Coleman
