• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Active Contributor
    elprim
    ACE2012 Link components & reverse component
    280 Views, 7 Replies
    09-11-2012 05:17 AM
    Hi
    What is the right way to unlink component
    I have reversed the component and then I wasn't able to connect wire,
     the connection was made over component, what I make wrong
    Thank for help, Vito
    Kind regards, Vito
    Please use plain text.
    Re: ACE2012 Link components & reverse component
    09-11-2012 05:58 AM in reply to: elprim
    How did you reverse the component? If you simply mirrored it, then ACE will not work properly. You have to use the "Reverse/Flip Component"Command. One way of finding it is to hover over the component and then Right Mouse Click. This command is located near the bottom.
    You can use "Trim WIre" to disconnect a component from the wiring.
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    elprim
    09-11-2012 06:30 AM in reply to: testsubject
    Hi, I used "Reverse/Flip Component" and result is in attachment
    block is VSS21 and VSS113
    Thanks, Vito
    Kind regards, Vito
    09-11-2012 06:36 AM in reply to: elprim
    Can you send the .dwg file? I cannot see how the symbol is created done from a jpeg...
    Bob Hanrahan
    Ace User since 1998
    09-11-2012 06:37 AM in reply to: testsubject
    Also what library are you using? IEC2, IEC4, JIC1, JIC125, etc? They all use the same file names but the drawings are different.
    Bob Hanrahan
    Ace User since 1998
    Active Contributor
    elprim
    09-11-2012 06:45 AM in reply to: testsubject
    I use IEC60617 and ACE 2013
    Kind regards, Vito
    09-11-2012 07:43 AM in reply to: elprim
    I am not sure what is wrong.
    I had no trouble reversing any of these contacts.
    Sorry that I could be of more help.
    Bob Hanrahan
    Ace User since 1998
    Distinguished Mentor
    09-11-2012 03:25 PM in reply to: testsubject
    When you reversed the contacts, did you check the box to only reverse the graphics?
    I've had similar problems in the past when reversing a component and found that if I didn't check that box, the attributes would also be moved but the wire direction wouldn't change.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
