• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Re: ACE2012 - Customizing Project Description Labels
    05-31-2012 09:03 AM in reply to: Outbound
    Be sure that your version of Windows is set to show file extensions.  This can cause problems when renaming text files because you can't see that the extension is already there.  In that case, you may end up with projectname_wdtitle.wdl.wdl.
    Doug McAlexander
    Electrical CAD Industry Specialist
    Independent Consultant/Instructor/Mentor
    AutoCAD Electrical, VIA/WD, Toolbox/WD, ecscad, promis-e, RSWire
    Web site: www.ECADConsultant.com
    E-mail: ECADConsultant@gmail.com
    Phone: (770) 841-8009
    Please use plain text.
    Active Contributor
    05-31-2012 09:42 AM in reply to: Outbound
    GOT IT!
    Case closed...thank you!
    New Member
    09-28-2012 04:51 PM in reply to: testsubject
    hello bob,
    i'm very new to autocad electrical and want to know how to create save a file with .wdl extension... when i try with note pad it only has .txt extension. i'm very confused...
    Employee
    09-29-2012 07:04 AM in reply to: dougmcalexander
    In Notepad if you want to save a file to an extension other than .txt, in the "Save as type" drop-down list pick All Files. Then enter the file name with the extension you want, in this case the .wdl extension.
    Pat Murnen
    Principal Content Developer
    Information Modeling and Platform Products Group
