• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    Accepted Solution
    ACE_PLC.MDB Issue
    367 Views, 9 Replies
    12-20-2005 05:21 AM
    My ACE_PLC.MDB file is located on a network so that all of our users can access it. I've recently upgraded to a new computer, and when I go to edit modules, the descriptions are blank for one entire PLC model. When I go back to my old computer, everything shows up just fine. Anyone have an idea how to get around this. This issue is also true if someone else edits the MDB file.
    Please use plain text.
    Re: ACE_PLC.MDB Issue
    12-20-2005 05:27 AM in reply to: MartinLee
    Get back your old computer, and never plan on upgrading?? hehehe Not using PLC's I have never had to deal with this issue, but it sounds like maybe the new computer is not pointing to the file on the network? Just a guess.
    Marty
    12-20-2005 07:35 AM in reply to: MartinLee
    DUH!!! Bad Guess! Since we use profiles, the search paths are the same. I suspect that this file wasn't designed to be used or modified across a network. I've noticed this issue before when someone else attempted to edit the file and had the same issues. The error message is regarding "Undefined Terminal Types", which is an error itself, as the terminal types are actually all there.
    12-20-2005 07:40 AM in reply to: MartinLee
    Yeah I have noticed that ACE seems to be very "Stand Alone-ish" Hope that changes some time in the future, hopefully before I have to network 3-4 machines together......8-)
    Marty
    *Mike Spitzer \(Autodesk\)
    12-22-2005 01:18 PM in reply to: MartinLee
    Martin,
    I believe that you have run into a logged issue. Try this for me. Type the
    following at the command line:
    !GBL_wd_DocSetBase
    This will most likely return to you the location of the Support folder in
    your Documents and Settings folder. It may look something like this:
    "C:/Documents and Settings/spitzes/Application Data/Autodesk/AutoCAD
    Electrical 2006/R16.2/enu/Support/"
    In this folder, you should find a file called WDMBBLKS.BSF. This file is
    the block settings file and contains among other things, the information
    that maps the terminal descriptions to the terminal blocks. The issue is
    that when you move your data for your PLCs (in this case you are sharing it
    on the network), Electrical is still looking for that BSF file in your
    Documents and Settings support folder. If you have made any changes to the
    Terminal Block Settings in the PLC Database Editor, these settings will be
    saved to this wdmdbblks.bsf file. When you do a new install on a new
    computer for example, the installed file will not have your additions or
    modifications in it, so you will get an "Undefined Terminal Types" error
    when you try to edit a module that uses the additional terminal types that
    you defined. The work around is to make sure that the BSF file that you
    have local matches the BSF file that you are sharing on the network (if the
    file is on the network) or that matches the file you had on your old
    computer. You can copy it over, but I would suggest making a backup first.
    You may need to copy this file to each users computer in order for them to
    be able to edit these modules as well. This is a logged issue and is being
    looked into. Hope this helps.
    Mike
    wrote in message news:5042189@discussion.autodesk.com...
    actually all there.
    12-22-2005 01:31 PM in reply to: MartinLee
    Thanks, Mike. That did the trick. This will also have to be done when installing newer versions of ACE, at least on the ones I am running now. I suspected that there was a file somewhere keeping track of the changes, just didn't know which one it was.
    Martin
    12-22-2005 01:32 PM in reply to: MartinLee
    Martin,
    After reading over your post again, I think the BSF file that is the latest
    is on your old computer. So if you copy it, copy it from there instead of
    from the network.
    Mike
    "Mike Spitzer (Autodesk)" wrote in
    message news:5044793@discussion.autodesk.com...
    Martin,
    !GBL_wd_DocSetBase
    Mike
    actually all there.
    12-23-2005 04:06 AM in reply to: MartinLee
    That's what I did. And if other users want to add a module, they will need to copy this file to their computer, then copy it back so they others can have the latest file. I have a batch file that copies all of our custom files to the proper ACE folders, so I'll add this one in. Thanks.
    Member
    05-17-2012 04:34 AM in reply to: MartinLee
    Has this issue been resolved? Or do we still need to use the workaround?
    dirtyc
    06-13-2012 07:41 AM in reply to: MartinLee
    This post is almost 7 years old.  Has this still not be resolved?
    I've been investigating sharing autocad settings across the network as well, and it seems that the issue is that ACADE is based on MS Access databases, which do NOT like to be shared.
    If this is in fact an MS Acess DB issue, and nothing Autodesk can help, would someone from staff please post so?
