• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Electrical
    Distinguished Contributor
    ACE 2013 wire layers go missing
    165 Views, 2 Replies
    10-05-2012 08:51 AM
    Is there an issue were wire layers go missing? I am finding myself adding wire layers back when I should not have to.
    Rgds,
    J.
    Please use plain text.
    *Expert Elite*
    Re: ACE 2013 wire layers go missing
    10-05-2012 09:33 AM in reply to: JeffatICS
    Just to respond that I have not seen this occur.
    Bob Hanrahan
    Ace User since 1998
    Distinguished Mentor
    10-07-2012 03:36 PM in reply to: JeffatICS
    Only when I run the Purge All command....
    As a workaround, try getting all your layers setup and then exporting the layer setup using the 'Layer States Manager'. Then when you need to add missing layers, you just import the saved layer setup.
    Regards Brad
    Icemanau (NNTP handle: Brad Coleman)
    You may recognize me from the
    hundreds of previous newsreader posts
    I've made over the last 5 years
    as Brad Coleman
