AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
ACADE 2011 "Locate File" error
- Highlight
- Email to a Friend
Everytime ACADE 2011 starts up it keeps giving me a "Locate File" window.
The File:
C:\Acade 2011\AeData\Proj\608661\608661-03.dwg is not fouind at the defined location, or in the project folder for project 608661. Click OK to locate manually.
The drawing IS in the directory!
I click OK, locate file and have tried the Open, and Locate buttons, but I keep getting the same error on strt up. I have even tried oipening the drawing and saving, but sane error.
Any ideas?
Re: ACADE 2011 "Locate File" error
- Highlight
- Email to a Friend
Hi Nathan,
Remove the drawing from the project. (right click on the drawing select "Remove")
Then readd it. (right click on the Project and Select Add Drawing)
should solve the problem.
James Alger
SolidCAD
- Highlight
- Email to a Friend
That fixed it. I had tried this before, but the project was not active. After making project active and doing what you said... everything ok.
