AutoCAD Electrical
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
6ES7321-1B H50-0AA0 symbol wrong in the 2009 library
- Highlight
- Email to a Friend
6ES7321-1BH50-0AA0, PLC digital input module is wrong in 2009 AE libray. It is not even input module, it is showing as an output module. Is there a correct symbol available somwhere for that module? I need to be able to split it so I can put 8 inputs on the left side of the drawing and second 8 on the right side of the drawing.
Re: 6ES7321-1B H50-0AA0 symbol wrong in the 2009 library
- Highlight
- Email to a Friend
Does anybody know if the correct version of this symbol is available?
Please help!
- Highlight
- Email to a Friend
I have attached my exported 2013 library of S7-300 digital input PLC database in excel.
Maybe you can try import or compare with your exisiting one to see if it helps.
Thanks.
- Highlight
- Email to a Friend
Thanks a lot for your help. The data in the excell sheet is correct, but I need Auto CAD symbol. Is it possible that you upload that for me. In my library the symbol is missing pin 20, and it is shown as output rather then input. I am attaching the drawing with it. If you have the symbol, would you be so kind to share it? Thank you in advance for your help.
- Highlight
- Email to a Friend
There is no such thing as a unique symbol when it comes to inserting from the PLC IO Database. The symbols are built parametically from the database.
I can tell you that pins 10, 11, and 20 are marked unused and do not appear when inserted unless you check the "Show Unused" box during the insertion.
Unfortunately, I do not have the time to do a detailed walkthrough for you on how to write your own or fix this one.
Maybe someone else can provide this for you.
Ace User since 1998
- Highlight
- Email to a Friend
Ok, I find it, I forgot that there is PLC database file editor. It's real easy to set the PLC cards there...duh...
- Highlight
- Email to a Friend
If you need to modify the exisiting PLC module, try to copy the existing one and just change the pins or wires insertion directions using PLC database editor and save your time to recreate a new one.
Thanks.
- Highlight
- Email to a Friend
