• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Active Contributor
    David_S_Barrow
    3D Move
    196 Views, 3 Replies
    05-27-2011 05:33 AM
    When I'm creating a 3D panel layout in AutoCAD Electrical 2011, if I decide to move an object using the AutoCAD Move command, whilst the object is on my cursor. I change my point of view using the orbit command all the other Objects in the drawing disappear? Which makes it impossible to use any other geometry to position my object.
    Please use plain text.
    hardin
    Re: 3D Move
    05-27-2011 01:20 PM in reply to: David_S_Barrow
    If you have an object selected, it will isolate once you begin to orbit. That is a natural feature.
    If you are issuing the Move command, THEN try orbit, it should continue to show everything.
    Try turning Hardware Acceleration off to see if that helps.
    Is the item you're moving close to the items you are moving to? If not, then maybe orbiting is just swinging the object off the screen.
    Learn, Practice, Get Better
    http://autocad-lkh.blogspot.com
    Active Contributor
    David_S_Barrow
    Re: 3D Move
    05-31-2011 08:42 AM in reply to: hardin
    I select an object to move it. I then use Shift + Middle Mouse button to rotate the display, the whole model stays visible whilst I'm rotating it but soon as I release the mouse button and shift key the rest model vanishes, leaving the part I'm moving which stays visible on the cursor. Turning off the hardware acceleration doesn't cure the problem just makes the model rotate very slowly.
    Distinguished Contributor
    s.wile
    Re: 3D Move
    06-02-2011 06:40 AM in reply to: David_S_Barrow
    Since this is more an AutoCAD question you may have better luck posting it over on the that group.
    Stan Wile
    Stan Wile
    http://myacade.blogspot.com/
    IMAGINiT Technologies
