• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Electrical
    Distinguished Contributor
    2008 Icon Menu
    85 Views, 2 Replies
    03-24-2008 08:58 AM
    Is there a way where I can have the default AutoCADE 2008 icon menu located on the network?
    Well let me start over. I have modified the default Icon menu and placed it on our network so that it can access our modified icon menu. I can toggle back and forth between each so I don't have an issue with that. However, when I place the ACE default icon menu on the network, I do not get any of the pretty pictures to come with it. Is there a way where I can get to see the pretty pictures? Do I have to copy all of the .sld files to that location?
    Or is it the best to modify everybody's standard AutoCAD menu file so that it can access our modified menu.
    Make sense?
    Please use plain text.
    Re: 2008 Icon Menu
    03-25-2008 09:02 AM in reply to: amt_controls
    Am I missing something obvious? If so, please let me know. Or if you think I may be doing something wrong also let me know.
    *Pat Murnen
    Re: 2008 Icon Menu
    03-25-2008 12:14 PM in reply to: amt_controls
    You might want to look at the online Help topic "Set up AutoCAD Electrical
    for multiple users". I believe you need to copy the files from the local
    drive to the network drive. You can put them in the same folder as the menu
    .DAT files or add a line in the wd.env as described in that topic.
    The files to copy are -
    ACE_GB.slb, ACE_GB.dll, ACE_JIS.slb, ACE_JIS.dll, ace_as.slb, ace_as.dll,
    ace_hyd.slb, ace_hyd.dll, ace_pid.slb, ace_pid.dll, bb.slb, iec1.slb,
    iec.dll, loc2.slb, pn0.slb, pn0.dll, pn1.slb, pn1.dll, pn2.slb, pn2.dll,
    pn3.slb, pn3.dll, pnl2.slb, pnl2.dll, pnl.slb, pnl.dll, s1.slb, s1.dll,
    s2.slb, s2.dll, Ww.slb
    in C:\Documents and Settings\{username}\Application Data\Autodesk\AutoCAD
    Electrical\{release #}\{country code}\Support
    and
    S_LDPC.SLB, WD_LOCAL.SLB, WDSIG.SLB, WDSIG_1.SLB, gepb.slb
    in C:\Program Files [(x86)]\Autodesk\Acade {version}\Support
    Pat Murnen
    wrote in message news:5883718@discussion.autodesk.com...
    on the network?
    location?
    Make sense?
