AutoCAD Electrical Forum
wire numbering
2 REPLIES 2
397 Views, 2 Replies
wire numbering
i need to carry the io address, wire color and gauge from start to finish as part of the wire number call out. i can't get the io address past the first connection and i can't get the io and color/gauge to come in together. any help would be appreciated
2 REPLIES 2
Does your assigned wire number also include the color/gauge info all
encoded into the piece of wire number text or is it separate text? How do you
increment the I/O address as you move away from it? Do you add a suffix to each
wire number like I:001/00, I:001/00A, I:001/00B...?
whether right or wrong we don't want unique wire numbers but are forced to because %n is required. our ideal wire number would be something like ORG-E4-5-18.
ORG - wire color
E4 - module
5 - address
18 - gauge
i can get the ORG and 18 when i tag the wires but i can't get the io address E4-5 to combine with ORG and 18 or keep the E4-5 past the first connection off the io module
”Boost
