AutoCAD Electrical Forum
wire number format
6 REPLIES 6
880 Views, 6 Replies
wire number format
Has anyone out there seen this before?  My wire numbers are giving the column number 1302 twice then the line number 11, I want to have the column number 1302 shown once then the line number 11 after that.  Here is an example of what I have and what I would like.
1302130211 is what I have this is what I want 130211
Under the drawing properties\wire numbers format tab I have %N and line reference checked.
Thanks in advance for any help!
6 REPLIES 6
cbenner
in reply to: cbenner
Here us a screen shot of the drawing properties.
Icemanau
What is your suffix setup?
Regards Brad
Brad Coleman, Electrical Draftsman
Hi Bad,
It could be that someone (not Mentioning any names... Smiley Wink) deleted a rung (using a normal AutoCAD Delete) and placed a second one in the same location, with the same Numbering scheme.
This would give you two %N values, creating a "Duplicate" wire reference.
If you run a "DWG Aduit" (from the reports tab) on the Page it should correct itself.
You may also need to force a rung update through "Revise Ladder".
(Schematic > Edit wires/wire numbers > Add rung drop down > Revise ladder)
Let me know if you still have issue with the drawings that trying those things. (Revise ladder, and DWG Aduit).
James Alger
Success!!!  I tried the "revise ladder" option and sure enough under there it was set to 1394%N I took out the 1394 leaving the %N and now it numbers my wires like it should.
Thank you for the advise and thanks to everyone else for there input as well.  It is GREATLY appreciated!!!
Glad I could help.
James Alger
”Boost
