AutoCAD Electrical General
bad
Member
bad
Message 1 of 7 (357 Views)
wire number format
357 Views, 6 Replies
06-13-2013 03:20 PM
Has anyone out there seen this before?  My wire numbers are giving the column number 1302 twice then the line number 11, I want to have the column number 1302 shown once then the line number 11 after that.  Here is an example of what I have and what I would like.
1302130211 is what I have this is what I want 130211
Under the drawing properties\wire numbers format tab I have %N and line reference checked.
Thanks in advance for any help!
bad@cad
cbenner
Message 2 of 7 (349 Views)
Re: wire number format
06-14-2013 06:02 AM in reply to: bad
Welcome to the forums!
Can you post a screen shot, or show how you have your wire numbers formatted in the project properties?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
bad
Member
bad
Message 3 of 7 (336 Views)
06-17-2013 06:37 AM in reply to: cbenner
Here us a screen shot of the drawing properties.
bad@cad
Icemanau
Message 4 of 7 (319 Views)
06-17-2013 03:26 PM in reply to: bad
What is your suffix setup?
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
algerj
Message 5 of 7 (291 Views)
06-20-2013 07:24 AM in reply to: bad
Hi Bad,
It could be that someone (not Mentioning any names... :smileywink:) deleted a rung (using a normal AutoCAD Delete) and placed a second one in the same location, with the same Numbering scheme.
This would give you two %N values, creating a "Duplicate" wire reference.
If you run a "DWG Aduit" (from the reports tab) on the Page it should correct itself.
You may also need to force a rung update through "Revise Ladder".
(Schematic > Edit wires/wire numbers > Add rung drop down > Revise ladder)
Let me know if you still have issue with the drawings that trying those things. (Revise ladder, and DWG Aduit).
James Alger
bad
Member
bad
Message 6 of 7 (263 Views)
06-24-2013 07:20 AM in reply to: algerj
Success!!!  I tried the "revise ladder" option and sure enough under there it was set to 1394%N I took out the 1394 leaving the %N and now it numbers my wires like it should.
Thank you for the advise and thanks to everyone else for there input as well.  It is GREATLY appreciated!!!
bad@cad
algerj
Message 7 of 7 (252 Views)
06-24-2013 08:19 AM in reply to: bad
Glad I could help.
James Alger
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
