Are you dismissing the dialog by hitting the "X" in the upper right hand
corner of the dialog or by hitting "OK" button? If you're hitting the "X" to
dismiss the dialog, I believe this is being treated the same as if you'd hit
"Cancel" and the configuration change is not saved. Let me know...
thanks!
Nate.
"lauraw" wrote in message
news:17559549.1087841586951.JavaMail.jive@jiveforum2.autodesk.com...
> When I select solid for wire crossing in the dwg configuration and close
dialog box, then insert a wire crossing another wire I am still getting the
loop. When I check the drawing configuration, it has reverted back to the
loop setting for wire crossing. Is this a bug or am I missing something?
> thanks for any response.
