See if this works... add double quotes around the complete path that
includes a comma
BEFORE:
WD,\\Flag\DataCenter\Customers\Invie Consulting\Moorhead, MN\CAD\Current
Projects\Library Files\Master\Support,AutoCAD Electrical dialog files, xls
templates, and other support files
AFTER:
WD,"\\Flag\DataCenter\Customers\Invie Consulting\Moorhead, MN\CAD\Current
Projects\Library Files\Master\Support\",AutoCAD Electrical dialog files, xls
wrote in message news:5513543@discussion.autodesk.com...
I am having problems with my wd.env file and am hoping somebody can give
some good advice.
The path to get to the files I need to reference on our network have both a
comma and a space. I see that I need to put quotes around the spaces, but
how do I deal with a comma?
I received advice from AutoDesk tech support who told me there were no
syntax errors in my env file except that I needed to change the forward
slashes to backward slashes. This did not help.
When I try to load the env
file with the space and comma in the path, AutoCAD Electrical 2007, stops
functioning correctly. I can still do many things, but I am unable to edit
any components or footprints, cannot do any project management, title block
updates, surf, etc. No amount of repairing will work. It takes a complete
uninstall and reinstall of ACADE to get it working again.
Since this takes some time, I would really like to make sure that I have
something with no known errors before trying again.
I've
attached the file I'm using for you to check it out.
