AutoCAD Electrical Forum
vfd & soft starters
6 REPLIES 6
dstron
5837 Views, 6 Replies
vfd & soft starters
I am looking for symbols or drawings for Square D vfd's and solid state starters. I have not seen any in the electrical package and was wandering if anyone had something i could use or modify.
6 REPLIES 6
krollenhagen
in reply to: dstron
Here are two drawings that I created using black box builder for some AB drives.
pmccutcheon
in reply to: dstron
here is an example of a Siemens MasterDrive VC Compact Plus.
made to fit A size sheet
controlsgirl
in reply to: krollenhagen
Is the "black box builder" the symbol builder?
SeedyNotions
in reply to: controlsgirl
Kind of. They're similar in that they get the same thing done. I believe the symbol builder has more checks and is easier to work with. Just don't close the symbol builder attribute window. I forgot how to get it back open.
controlsgirl
in reply to: dstron
Thanks! I've ran into the problem of closing the attributes toolbar before too! I can never figure out how to bring it back. How do you use the black box creater? Or what do you do to get to it.
SeedyNotions
First make sure you save whatever component you arer working on in a new cad file. Then just hit 'BB' then press Enter to open the black box editor. In symbol builder I remember how to open the attribute pallette. The command is AEPALETTESHOW. There is also a toolbar floating with a blue and yellow ligthbulb. But the command is guaranteed.
Hope this helps.
”Boost
