AutoCAD Electrical Forum
updating symbols, icons, etc. in ACE2005
3 REPLIES 3
david_brown
190 Views, 3 Replies
The merge database utility in AE2005 works great. Any way to merge the symbol files, plc.dat files, symbol menu icons, etc. from ACE2004?
3 REPLIES 3
david_brown
in reply to: david_brown
meant to say catalog database
rstein
I have an answer for you about the plc dat files. if you go to Projects pull down menu, then the Extras sub menu then select PLC DAT file to MDB conversion will take care of the plc files for you.
MartinLee
We had to rename the ace_plc.dat file to something else first, then run the merge utility to get our custom plc files to work. ACE 2005 will create a new ace_plc.mdb file when the merge is run.
Martin
”Boost
