hiii dear all,
i am trying to insert blocks using a macro(VBA program). iwas able to insert some of the components blocks but for some of the block it is unable to insert the block... can anyone help me in this?
Rajkoti
That sounds like a malfunction within your VBA code, not AutoCAD Electrical, especially since other symbols inserted correctly.
hi thanks alot for your reply.
i checked the program. using the program i am able to insert all the blocks except the three blocks. it is showing all the blocks correcly in the program. i have a doubt wheather it is because of missing blocks in the menu.dat file.. i dont how it effects while inserting the blocks....if it is required to update teh menu.dat file then please explain me the procedure.
i checked the program. using the program i am able to insert all the blocks except the three blocks. it is showing all the blocks correcly in the program. i have a doubt wheather it is because of missing blocks in the menu.dat file.. i dont know, how it effects while inserting the blocks using VBA....if it is required to update the menu.dat file then please explain me the procedure.
