I believe you can get these project descriptions with the following lisp
(setq lst (nth 1 (c:wd_proj_wdp_data_fnam (ace_getactiveproject))))
The return is a list with the first element, nth 0 as nil so that LINE1
would start at nth 1.
Hope this helps,
Pat Murnen
wrote in message news:5712863@discussion.autodesk.com...
I am trying to write a LISP file that maps different lines of my project
descriptions to a common attribute name on my title block based on my dwg
name. For example, if I have a drawing ##322-54####.dwg, and the first ##
equals 21 and the last #### equals 1000, I want to map LINE13 of my project
descriptions to my title block attribute named SERIES_NUMBER. I have the
LISP file current working to read the file name correctly, but the problem
is that LISP does not know what the LINEXX is. Is there a global variable
that I can access my project descriptions, or how do I get LISP to
understand the LINEXX or the string of characters for LINE13 of my project
descriptions. I have attached my .wdt file that I am trying to create this
functionality into.
