Does anyone have a solution?
When running reports we often find it nessecary to include the Drawing
Number in the report. For example when running a Wire To/From report we may
wish to include the Drawing Number that a wire comes from as well as the one
it goes to. The report manager allows this by selecting the "DWGNAM1" and
the "DWGNAM2" fields in the "Data Fields to Report" dialogue. Now I believe
that the values placed in these fields are derived from the %D field of the
"Drawing Config & Defaults".
I am able to auto update the %S (Sheet No.) value to the "Drawing Config &
Defaults" by simply doing a Title Block update and "Resequencing" the sheet
numbers. However, if I want the value to be filled into the %D this is a
manual process that has to be done in each drawing's configuration or by
editing the WD_M block's tag SHTDWGNAME in each drawing. For some this may
not be an issue but it would certainly be nice to be able to set that tag =
to another one say for example the the FILENAME. If there was a way to do
this one could auto update the SHTDWGNAME attribute across the entire
project and never have to fill it in manually...of course saving time. Does
anyone have any suggestions on how we could do this? My guess would be a
lisp routine that allows one to set the SHTDWGNAME value = to another value
and then run this lisp through a script and use the AutoCAD Electrical
Utilities to launch that script across the project. Then the resulting
value could be used for whatever one chooses.
Any suggections would be greatly appreciated...
Wayne Gatlin
