I suggest only inserting one terminal symbol in the schematic per terminal symbol in the panel layout. In the example I posted the Jumper-Bar represents the connection in the middle of the block. There are two RED #14 wires connecting to the terminal as well. The angled wire symbol depicts this. (see attached image). If I need to connect from the same terminal to a circuit on another page, I use a source arrow and connect it to one of the RED #14 wires. I insert the destination arrow on the other page.
If you have your terminal block properties set to only allow 4 connections per block, and you connect a 5th wire to the block, once you get to TSE to prepare for inserting the graphical strip, AcadE will automatically add an additional block to accommodate the 5th wire. For example, if you use the HT0W02 style block that is marked with the wire number of the node, and you have its block properties set for 4 wires max, connecting a 5th wire will force TSE to insert an additional block. This is normal, because TSE is trying to adjust the terminal strip to accommodate all of the wires you wish to connect to the strip. This is okay because all terminals in the strip get the wire number. But if using HT0002 where each terminal is marked in sequence, you could end up with two terminals marked as TB4:3, the original one from the schematic, and the extra that TSE adds in the graphical strip.
The bottom line is a term I have coined as “Design Reality.” Design your schematic in such as way as to mimic the real world. AutoCAD Electrical’s original name was Toolbox/WD, then it was called VIA/WD. The WD stands for “Wiring Diagram.” The program was born from the need for an intelligent way to depict wiring diagrams. It is very well suited to allow us to create both a schematic and wiring diagram all in one. If it were plain AutoCAD you could get away with murder, like the old days, but you would have no intelligent link to the panel footprints either, and no bi-directional updates, and no automatic BOM reports, and wire lists. If you only want one occurrence of TB4 terminal 4 in the panel, then only insert one instance of it in the schematic.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
