I am not sure if anyone else has noticed this and have been just dealing with it for a long time but something about this function is not acting properly. It appears to do most of the layers except the WD-Wires layer. I always have to manually do this layer.
I always select "Change to new WD_M Block, Values, Layers" and select the wd_m.dwg located here:
C:\Program Files\Autodesk\Acade 2006\Libs\jic1
This is from the command window:
_________________________________________________
PANEL:
Type "swap_pnlm" to swap and conv to new lays carried on new wd_pnlm.dwg
Type "swap_pnlm_keep" to swap but keep drawing's existing layer names
SCHEMATICS:
Type "swap_wdm" to swap and conv to new lays carried on new wdm.dwg
Type "swap_wdm_keep" to swap but keep drawing's existing layer names
Command:
Change WD-WIRENO to WIRENO, ents moved: 6
Change WD-WIRECOPY to WIRECOPY, ents moved: 0
Change WD-WIREFIXED to WIREFIXED, ents moved: 0
Change WD-TAGS to TAGS, ents moved: 9
Change WD-XREF to XREF, ents moved: 4
Change WD-DESC to DESC, ents moved: 21
Change WD-TERMS to TERMS, ents moved: 51
Change WD-XREFCHILD to XREFCHILD, ents moved: 2
Change WD-DESCCHILD to DESCCHILD, ents moved: 4
Change WD-LOC to LOC, ents moved: 9
Change WD-POS to POS, ents moved: 0
Change WD-MISC to MISC, ents moved: 113
Change WD-LINK to LINK, ents moved: 4
Change WD-SYMS to SYMS, ents moved: 18
Change WD-TAGFIXED to TAGFIXED, ents moved: 0
Processing terminal and signal arrow wire number text...
2 WIRE TERM and SIG ARROW text ents moved to layer WIREREF
_.REGEN Regenerating model.
I hope this helps,
Robert Hanrahan
ACE user since 1998
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
