Hi all,
I am trying to change the wire layer format automatically (specifically turning OFF wire numbering) for several drawings I have. I am aware of the "Create/Edit Wire Type" but want to automate it using maybe a script. I did do a search but came up empty. Anyone try this yet??
Robert Hanrahan
You'll have to create a program to achieve this. My investigation found that this setting resides in an xrecord in the actual layer.
So.. lisp/vba/.net... Go on 🙂
THL
Since I was already on it.. here's some VBA code to set the Wire Numbering On/Off...
Option Explicit Public Sub Test() Call SetLayerWireNumbering("WIRES", True) End Sub Public Sub SetLayerWireNumbering(ByVal LayerName As String, ByVal WireNumbering As Boolean) Dim Layer As AcadLayer Dim Dic As AcadDictionary Dim XRecord As AcadXRecord Dim XRTypes As Variant Dim XRValues As Variant ' Step through all layers For Each Layer In ThisDrawing.Layers ' If layer name matches the Layer to be changed... If StrComp(Layer.Name, LayerName, vbTextCompare) = 0 Then ' If layer has dictionary... If Layer.HasExtensionDictionary Then ' Get dictionary Set Dic = Layer.GetExtensionDictionary ' Get first XRecord in dictionary Set XRecord = Dic.Item(0) ' Get XRecord data Call XRecord.GetXRecordData(XRTypes, XRValues) ' Set "bit" for Wire Numbering If WireNumbering Then XRValues(24) = 1 Else XRValues(24) = 0 End If ' Write XRecord data Call XRecord.SetXRecordData(XRTypes, XRValues) ' Exit the layer loop Exit For End If ' If layer has extension dictionary... End If ' If layer name matches the Layer to be changed... Next ' Step through all layers End Sub
Copy/Paste this into the THisDrawing module in the VBA editor, and experiment with the Test-subroutine.
This could also be implemented in a script if needed.
THL
Thanks for the response! I will give this a try and let you know how it worked out.
Bob
