ok
I am working on a project supplied by my client and has been worked on by more than one person heres my problem
because more than one person has worked on the drawings and had free reign on what they did there is absolute chaos in the cross referance arrows what i mean in the code descriptions there is random referancce numbers mixtures of numbers letters sometime page numer is in there or device tag number no fixed easy to read format
what i want to do is edit this chaos to a level where i can actuly make sence of this mess
i have worked out what im going to do and its this
the new code will now be wwww-xxxx-yyyy-zzzzz where wwww = installation code xxxxx=wire number yyyyyy= page number zzzzzz= sequence number starting at 1
this will make it easy to figure out where the wire orignated from when checking wires
now the issue is there an easy way i can edit the arrows without going to each arrow individully and putting the information in because i have liturally weeks worth of manual editing to do
Solved by kc8akw. Go to Solution.
Perhaps this will help:
Using the Import/Export Data tab, select To Spreadsheet. Pick the Wire number signal arrows radio button and save to a spreadsheet.
Edit the spreadsheet SIGCODE column.
Save the file.
Using the same tab, import back into the drawing using the From Spreadsheet option.
my brain must have been fried at that pint i been dipping in and out of the spreedshheet utilty for weeks now and i didnt think to check there !!!!
