AutoCAD Electrical General
Distinguished Contributor
acade2012
Message 1 of 5 (443 Views)
sheet number lisp rotine help
443 Views, 4 Replies
12-04-2012 06:56 AM
hello All,
I am tring to develop a lisp routine to change the sheet number to match the last 3 digits of the drawing number.
I have been able to get and write the proper number the the sheet value but it adds it to the existing sheet value.
Can anyone help me with deleting or overwriting that sheet value before i add the correct value??
Dennis
(prompt "\nType AAA to run.....")
(defun c:aaa ()
        (COMMAND "-ATTEDIT" "N" "N" "WD_M" "SHEET" "" "" (SUBSTR (GETVAR "DWGNAME") (- (STRLEN (GETVAR "DWGNAME")) 6) 3))
 (princ) )
the result finds the correct number and adds it to the existing sheet number i need it to overwrite the sheet number
acade2012
Message 2 of 5 (428 Views)
Re: sheet number lisp rotine help
12-04-2012 08:50 AM in reply to: acade2012
I did notice with the 2nd set of empty "". this is looking for a value to search for and replace. If i put in the current sheet value is changes it correctly.
the issue is that value changes from drawing to drawing.
I tried to get the current sheet value out but I am not having any luck.
i have tried the follwing
SETQ SHTNUM (GET_ATTR "WD_M" "SHEET" )
SETQ SHTNUM (GETVAR SHEET)
ANY IDEAS?
acade2012
Message 3 of 5 (420 Views)
12-04-2012 11:17 AM in reply to: acade2012
HERE IS WHAT I ENDED UP FIGURING OUT
FIRST LINE CLEARS THE SHEET NUMBER AND THE SECOND COPIES THE DRAWING NUMBER (ISTATING AT INTIGER 6 GOING 3 PLACES)
HOPE THIS WILL HELP SOMEONE!!!
(prompt "\nType SHTNUM to run.....")
(defun c:smileyfrustrated:HTNUM ()
     (c:wd_modattrval (ssname(ssget "x" (list (cons 0 "insert")(cons 2 "WD_M"))) 0) "SHEET" "" 1)     ;CLEARS SHEET VALUE
        (COMMAND "-ATTEDIT" "N" "N" "WD_M" "SHEET" "" "" (SUBSTR (GETVAR "DWGNAME") (- (STRLEN (GETVAR "DWGNAME")) 6) 3)) ;SET SHEET VALUE=DWGNAME
   (PRINC) )
Member
erg.cgs
Message 4 of 5 (214 Views)
11-12-2013 10:42 AM in reply to: acade2012
This worked perfect for me. One thing, the "SmileyFrustrated" (:smileyfrustrated:) is really a colon (":") followed by a capital "S".
rhesusminus
Message 5 of 5 (199 Views)
11-13-2013 02:21 AM in reply to: erg.cgs
This "short version" does the same... No need to clear the value and then use the -ATTEDIT to set the new value. Just set it directly.
(defun c:SHTNUM ()
     (c:wd_modattrval (ssname(ssget "x" (list (cons 0 "insert")(cons 2 "WD_M"))) 0) "SHEET" (SUBSTR (GETVAR "DWGNAME") (- (STRLEN (GETVAR "DWGNAME")) 6) 3) 1)
 (PRINC)
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
You are not logged in.
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Ask the Community
